stallion85
That looks nasty
454k30 said:So where are all your trail pictures from moab? Sorry I couldnt look you up when I was in nellis, we were swamped with F-18 radar crap!
muddybuddy said:do you have any pics of the front fenders finally cut with the 42s? im trying to see if there is a way i can keep the inner fenders with 6" susp and 1" body with 42's![]()
smokkey1 said:looks killer! do u have anything planned for the truck before the tin benders event?
MuddinManny said:I have a question for you. I noticed that you mounted ORD's X-Over Steering arms backwards, with the arms facing toward the pinion yoke. Why? Did it clear okay, or did you have difficulties. What does this do for your trucks undercarriage?
I have the x-over kit and am looking at this with interest. Can I ask you to help a wheeler out?
Thanks!
Manny
flatbed it going to be sweet... are u locked up front? are u going with VV4W's?
stallion85 said:I actually have WFO High steer arms. The draglink and tie rod I got from ORD.
The skinny on the high steer arms is this: When I put them on originally I found out the oil pan sat on top of the tie rod once it was moved up and behind the axle. I opted to just buy a beefy tie rod replacement instead of notching the oil pan and or customizing the tie rod to clear it.
Now the WFO arms accept the larger taper shank of a draglink end instead of the tie rod end that my original ORD draglink was setup for. Instead of taking the draglink to a machine shop to have it cut down to accomodate the new longer body DRE and tapped. I just swapped the arms around and am using the end which was originally meant for the tie rod.
Looks pretty gay, but I threw away the old kingpin caps and needed to use both arms.
I welded the front up (bad decision) had no funds and don't like wheeling with an open front. I know a bunch of the VV4W guys, but am going with my 2 friends Trevor and Travis. They have nice Heeps and we pretty much are our own club......
i too will soon have an "ultimate m1008 thread"
but im using some slightly different parts than you so i think the 2 will be able to co-exist
