Alan2smiley
I'm in the shop
Bumpstop plates bolted through ubolt plates.
I'm done, you can go to bed now.You’re keeping me awake dang it! Haha
LolI'm done, you can go to bed now.![]()
ThanksDang man! I knew your truck was cool, but I had no idea it was so purposefully built and so beautifully executed!!!
The stack is universal depending on the task, when camping if it dosent get covered and it rains black crap comes out of it all over stuff. around the shop moving trailers, in the woods the stack works better.Dang! Just when I was going to say I liked the stack you went and deleted it. I see you are running the VE rotary pump and not the inline like "everyone" thinks you need to.
Yeah same here! Glad I didn’t see this before I started building my bed! I’d never be able to afford to finish it! Haha! This has a lot of the stuff I wanted to do to mine with storage and the airbags but I gave up on them because I couldn’t figure out how to do it. Can you give some more details on the bag setup? I thought about long travel bags, and then I thought about having them free on the top of the bag with a pad on the frame but I didn’t think it would work. Now seeing how yours is set up it is definitely going to happen. Wish I would have left the gooseneck hitch in it now...Dang man! I knew your truck was cool, but I had no idea it was so purposefully built and so beautifully executed!!!
1988 V3500 Crew Cab. was 2wheel drive single wheel EFI 454 400. Swapped Cummins 4bt, 6BT exhaust manifold cut and flipped, HX35, piston supply pump. lord mounts, summit racing radiator and electric fan kit. Dodge engine plate, bellhousing and input. NV4500 with GM 32 spline round pattern twin stick (ORD) 205 cast tailhousing. 1410 yokes front and rear shafts. GM Dana 60 front, 70s Chevy van Corp 14 rear with disk. 1410 gears with ARBs. 12.5 37 17 BFG AT on H2s. Wheel base 1.5" more than stock burban?, Disk Drive line parking brake, 12" slide on front shaft, Bilstein 7100, king 2.5" bumpstops in front, adjustable timbren rear overload Bump Stops. DIY4x4 B52, rear shackle and mounts + other stuff. Early 2000? GM 1/2 ton rear leafs. ORD 51" front leafs, PSE steering box ready for assist, cross over steering + other stuff. rear frame rail flattened and bobed at 4'9", Warn Zeon 12 with 3/8"x75' Master pull line, 40 gallon (31 operating) Schwan's truck fuel tank, tuffy Security console, Pro-Comp Full sweep boost, pyro, and fuel, Stewart Warner Full sweep diesel tack- info from alternater, four Corbeau Baja XRS seats, save big money carpet pad under rubber roofing floor mat. Lots of help from local professionals like, pipe fitters for welding SS, three different shops that bent tubing, machinest list is endless and Amish for bending aluminum. OMG no wonder it took 8 years to put together.But Alan, we need build up pics and descriptions.....please?
Yeah I made the timbren overloads ajustable so they kinda half ass multi task, They work okay just little noisy when close to the axle.Those are these http://timbren.com/ Fancy looking bumpstops that are actually rubber springs. International runs them on a lot of there medium duty trucks. They basically ride on them all the time as a supplemental spring. Summit Racing has them I think.
