Built White truck A.C, links and coilovers (35 PSI boost!)
2-4wheel 4BT conversion
I would typically use the black truck but the flat bed is getting blasted and I don't feel like useing the trailer. I also have to ship a 1 liter 3 cylinder Honda engine tommorow so that's going in the back, if it squats to much I'll lower the timbren overloads.
Alan, you have done such an excellent job with your truck that I have seen it in person and never realized how much time and work you have into it to create such a modified versatile fun vehicle. I should of looked closer! ha ha :waytogo:
Thanks! It's definitely a lot of work and time but worth it when it can be used for work and play, I don't use it for work but just in case I could. :D
Except for ice, fresh bakery items, beer and a few other consumables the truck is loaded for three nights of camping and couple of days blasting around the dunes.
Can't wait to hang out. Your truck is so well thought out and executed. Safe travels. Adam and I are on the same sites as last year.
Thanks! Your K5 is looking pretty sweet! See you soon. :waytogo:
Picture is kinda dark, the copper air line that feeds the ARB caught in the ring gear, tomorrow I'm going to bypass it and see if it works.
Air pressure is back to normal. The front drive shaft is pretty sloppy after 10000 miles, most driveline shops say throw it away and they will build a new one for $550. :haha::haha:
I bought this spline and 1410 yoke from high angle driveline, he has a newer upgraded version with coated splines with 1410 yoke and boot that was not available when I bought this one.
I'm sure this has been mentioned thousand times, my steering wheel turns slow even with higher RPMs.
