Burnt burb resurrection (It's mine again!)
Gas really shouldnt leak out of there unless the injectors are hanging open and filling the "venturi" The throttle shafts are known to be a source of vacuum leak though! When i rebuilt mine i just stacked o rings on the outside, over the throttle shaft, in such a way that the or ing held tight to the shaft, and tight against the outside of the throttle body. THat sealed up the vacuum leak i had right there quite perfectly. Also, Later model TBI's like 95ish had sealed bearings for the throttle shaft instead of bushings if memory serves me right.
If I have bushings their shot. I noticed when looking for seals that I had at least noticeable, side to side movement. You can see the gap. but theres no bushings in the kit??.. I got a Tbi Total rebuild kit.
Kit doesn't include any sort of bushings
Wonder if this is where my large cold vac leak i have is coming from....
I could easily see this causing a major vac leak. I'll get close ups tomorrow
Here is a video of mine I made before I had it re bushed and added o rings.
And another. You can see the smoke pour out of the throttle shaft.
Can I use a 95/96 base? That would be easy to find for cheap if I can:thinking:
I'm thinking that gas wouldn't come out of there if I wasn't making pools of it on top of the venture plate's... That should be cured with this rebuild I hope. As for the vacuum leak side of things, mine would totally fail that smoke test you did on yours.
also, during the rebuild / cleanup process, I found this tiny orifice to be all gunked up... nowhere said to clean it or how so I pulled a strand from a wire brush n shoved down there....:dunno: hope that's good enough
well there does appear to be some sort of bushing/seal.... so I decided to take the rest of it apart and see what I could do to replace em, and broke a screw immediately :doah: I'll take it to work and drill n' tap a new screw hole next to the old one. I kinda don't know if I wanna end up doing all 4 though:dunno:
there are felt like Oring type seals under them black caps.... there are some similar in the kit:rolleyes: Guess they DO come with replacements lol... I have it all apart now and will be putting it all back together tonight... at least on the bench... probably back in the truck tomorrow since it'll be almost 30* warmer, and I'll get my plugs done at the same time...... hopefully she runs smooth after that...... where's the crossed fingers smiley:popcorn:
I've got a spare throttle body sitting here. Yours for the cost of shipping if you want it.
the seals in the kit LOOK like the ones I pulled out of the black caps.... but clearly are not for that :doah: Now I don't know what to do.... if I use the O rings I found then i'd have a rubber stopping block thing on there that to me seams like it could easily seize or catch and make my throttle stick open:eek1: So im stumped as to what I should do:dunno: I'll try em for a bit and I should be able to tell befor it goes full stick on me if im going to have an issue or not... pics later
I gotta finish a few small things but its set together for now but I'm close:D
Before n after quick shots
Well I haven't turned down the pressure yet but I decided to drive it to work yesterday... Did great there and back... (About 20 min 1 way) No difference with the mods down low but when I passed a semi it kinda zipped around it and wasn't running out of steam towards the front like normal.... that was different.... and when kicked back cruising at 65-70 it wasn't hunting gears like it used to...:dunno: I hope this is for sure gone because it was the main reason I avoided taking it on interstates. taking it to work again tonight.
also on hind sight I realized I should have left a coulple of triangulated bumps on the top of the TB for centering the gasket and salad bowl:rolleyes: oops lol
Well apparently the pressure was too high for cheap injectors lol... so they're coming out (popped one) and I ordered AC delco's. they should be here tomorrow. hopefully that's the end of it getting towed for a while.... (forgot to mention that:whistle:)
yeah, watched it coming out around the electrical prongs like snake venom off fangs... neat looking lol.
