Yes you can . But have you priced gears and good install kits ? I rather bolt in and change oil . Locker or posi is stupid money for them even . BIG axle BIG money .
I am the same, I am done buying and selling.It amazes me that there aren't more of those around in this area. I've seen 2 or 3, and there were from your area!! I'm done buying and selling stuff, but I still look for stuff. More or less an addiction, can't not look for stuff lol. Only way to get one cheap is someone who doesn't know what they are...I'll look around, I drive all over this worthless state......
What's the difference?@b454rat what trans bad ? I have a spare 4500 for hd truck .
Long output shaft and parking brake on tailshaft for our 3500-hd trucks be it nv4500 or 4L80-e.What's the difference?
I thought chevy nv4500 is the same
Oh that guy . . He is asking STUPID MONEY with no hubs or other rear to match .
These in 4x4 only were 5.13 gear and a dana 80 rear with odd ball 37 spline .
His price with all he has missing is just crazy .
And here is how it looks when i click it . View attachment 497883
I believe @ZooMad75 has also mentioned they have a taller shifter tower.Long output shaft and parking brake on tailshaft for our 3500-hd trucks be it nv4500 or 4L80-e.
Gotcha.Long output shaft and parking brake on tailshaft for our 3500-hd trucks be it nv4500 or 4L80-e.
The gmt800 4500 is the tallest version. The 3500hd version is shorter like the rest of the gmt400 trucks.I believe @ZooMad75 has also mentioned they have a taller shifter tower.
they did dana 70 with the THICK snow fighter inner c-ends . and some other little tweeks .So it'd be a little work to fit a D60 under there?
The lug pattern change to 10lug with part of the pattern overapping is crazy money .Take a 99-04 ford 60 and extend the tube on the short side and toss on some nice inner Cs. 79 ford shafts and there’s your housing. You can run 4.56 without much issue I’d say. Probably pretty easy to get an adapter set for the lug pattern?
