just do NOT use a inner nut for a 4 tab style with the index pin for this . you might break the pin off and be sol.To pull the hub seal out: remove the spindle nuts and outer wheel bearing, put a spindle nut back on a few threads. Grab the rotor and pull off the entire hub assembly off the spindle.
this trick works GREAT 95% of the time . some setups it wont work . but i just did it on my 60 front so it will work for you .
Stage8 I am a fan!
