Wasatch K5
Wow!!!
I think this is the best write-up I've seen in a long time. You did an excellent job explaining the process and the photos helped a great deal. A very sincere Thank You!
I do have a few questions:
I have upgraded from a 208 to a 241 transfer case and would like to do this modification. I know GM started using the 241 in 1989 and Dodge started using the 241 in 1988.
Assuming I get a Dodge 241 T-case, do you know if this modification will work? And what (if anything) would be different?
In terms of re-orienting the cone and drilling and tapping the rear case casting, is there anything that would prevent one from TIG welding a boss and having that extra metal to drill and tap?
Thanks again.
Thanks again.
