beags86
Eastbound and Down
I have been there and gotten burned, just trying to save you from the same
I understand that but I don't get that you spend all this time on fancy cad drawings and bend tube and cope like a real deal fabricator, then when someone gives you constructive criticism your hard headed and unwilling to listen.... And you want this to show off your talents and get side work.
is adding the middle gusset stronger than no gusset, absolutely..
at some point, could it's impaling attitude override that and cause ejected flaming religious women?possible, quite possible...
There needs to be a point though... I understand it can create a tear point. But its also going to add some more strength before it does indeed tear. These ones are not welded in, so i can easily cut the tacks and move them up.
I see so many people build half the cage I have and never get any flack for it. Thats why I try and argue it.
I think the gussets will be ok. They can't make it any weaker than no gussets.
Dammit, I just want to go to the dunes. Ok ill move gussets out![]()
You don't HAVE to finish up the cage before you start hitting the dunes...![]()
