I never said anything about alum heads.. I'm all for iron.. Mines that way, but not measuring anything doesn't make sense whatever it's your motor, it will blow up again if you don't correct the issues.. It's cool though makes for good reading
this is like an episode of the golden girls
A bunch of stuff? Literally its just the pushrods to make the aluminum heads work otherwise they will bolt right in place of the iron heads. Both heads need the same machine work so I still say its stupid to spend the money twice and do the labor twice. Besides, he still needs to properly tune it no matter what heads he puts on.Exactly.... We know that if Deuling wanted to do the aluminum heads, he would need to get a bunch of other stuff in the motor first. With the iron heads, he has a known good setup and if he fixes it the right way what's the big deal?
Oh and since you are waiting on the Lobeotomy Special swap, remember the new 4.3 is LS based, cheaper than hell with low mileage ($2500 with a 6l80e and 8000 miles), alum, makes 285 on gas and 295 on e85, and is perfect for twins turbos pushing 8+ psi.
Just look really close at the emulshion tubes that come out of the top of that carter afb. I had one fall out when I was silly and thought they were good carbs. It made one side go lean.
No they don't. The iron heads just needed magnafluxed and he was taking the valves out and checking. He said they didn't need deck or anything. Magnafluxing costs like $15 a head.
Where are these.
And yah lets stop kicking the horse. Put it back together, I have an air fuel mixture gauge installed now, drilled and put a bung on the exhaust. Have a jet and metering rod kit in the mail. And im actually installing a timing mark and getting true TDC and timing by light and not by ear.
So no it will not be the same results as last time. So lets let it rest. Ck5 is full of too much bitching these days. I want to get back to playing, not wrenching.
I wasn't bitching, I was fathering. I wish I lived closer so you could see this is me. If you didn't have a timing pointer I am a little disappointed. Emlusion tubes push into the top of the carb, little brass tubes.
It only seems like there's been a bunch of bitching lately cuz you damn hillbillys up in mitchagin keep doing **** wrong.
But I think on this one you got it right.
Just make sure when you do a LS swap you get a 5.3 instead of a 4.8 cuz it's pointless to do a 4.8 for the money
Yeah! 6.2l diesel, so you can be cool like Rich and crawl the dunesI wouldn't waste any time on 4.8 or a 5.3 those are girl motors lol if your in there might as well swap a 6.2??? Better heads pretty much better everything..
