bp71k5
3/4 ton status
If you have crazy soft springs that let the axle move too much I suppose crossover can make things worse. Mine is awesome and have no trouble on the highway at 80+. But I have relatively firm TC 4" lift springs.
A vote up for crossover: I am not commited to my current springs. At the least, the fronts could use new bushings if there is a problem. Stepping to new springs all around is within the scope of possibilities -- I'd have to justify it somehow beyond just having a lift.Mine is awesome and have no trouble on the highway at 80+.
Offroad DesignWhere did you buy yours from?
I have more-bump steer with crossover steering, lots more! I have to tell anyone driving it for the first time to NOT pay attention to the steering wheel direction but the truck's direction! My father called it "nerve-racking".
I can only say I have no panhard bar and no sway bar with crossover steering. The thing doesn’t wander or have bump steer. I had much more wandering with the stock steering, but was using the factory rag joint.To answer the previous questions about Fords with factory “crossover” steering, they also have a panhard bar parallel to the drag link that mitigates the bump steer issue at the expense of articulation and also ride quality. The panhard bar binds against the free travel of the leaf springs but keeps the steering manageable to average drivers at highway speeds…
Crossover with no panahard bar and no sway bar has as much or more bump steer and wander as the factory push/pull arrangement. The benefit is full steering at full articulation on the trail at the expense of highway manners.
For mildly lifted and mildly driven trucks stock steering is usually the best answer!
I’ve got exact same setup and response.I run crossover on a 4” lift with a d60 and 37’s and it drives way better than the factory push pull system ever did.
