DJz Blazer
What 14 bolt is closest to being a bolt in?
From what I've read I will need to do spring perches, shock mounts, and probably go to 8 bolt wheels. But is there a 14 bolt with factory rotors that is close to the same width as my stock 12 bolt??
And what 60 bolts in up front??
Square body K30 axle stuff is pretty much bolt in for 1st gen K5s. Rear drums, but Diy4x4 makes a bolt on disc kit using K20 rotors and calipers on the FF14B. But you'll loose your parking brake.
The short answer for perches being in the correct place is the following: all fronts swap, 1st gens need a K30 rear, 2nd gens need a K20 rear
Thank you. Does it matter what year?
After spending a half hour searching the engine bay, starter area, frame rail, and floor...
I found the hide and seek champion....
I hate when they do that. Had a socket extension do that didn't find it till I couldn't move in 4wd
No, the tee off of the front of the carburetor.
Martin
On end goes to the vacuum advance on the distributor not sure about the other. I'll have to stick my head in there tonight when I'm doing the pinion in the rear end.
No, there is a different vacuum line going to the distributor. Your PCV valve has a hose running off of it to a T, the T runs to the carburetor, and the other end runs out of the picture.
Martin
Ah, to your charcoal canister.
It's not on that side on the newer stuff.
Martin
New torque wrench worked great. Now I need to get the front end done and figure out what's leaking in the gas tank.
