o.k. sofar mrk5 is in the lead for the closest guess . . . anymore ?
Holding on a bag of marbles...Zip tie on the driveshaft
done that to a guy 3 days in a row . 3rd day he just drove off with his middle finger flyin out the window .Zip tie on the driveshaft
rear axle is easier than going through 2 t-casesZip tie on the driveshaft
Loose nut behind the wheel.
I'll die laughing if it was a lugnuts in the hubcaps.
I'm scratching my head on a clunk right now too. As you may know I just had my 205 and 465 rebuilt. I also replaced both front and rear shafts. I get a bad clunk on hitting and letting off the gas. I've always had some driveline slop, I have a detroit locker in a 14bolt. It's been bugging the crap out of me. New rebuilds and new shafts make me want new tight tolerances and no leaks(thought I would throw that in there).and road test after swapping the atf for new 80-90 oil with 1/2qrt of lucus oil stabilizer in each box got even less noise .
but sadly i have work to do yet on the clunk .
its there in rear drive high & 205 rear low.
also there in rear high & 203 low.
its a lot less in front drive only . that level of clunk i could live with .
so i think its time to recheck pinion angles and shaft working angle and t-case rear yoke angle . prob pull the shaft of even just the 14ff and check pinion to ring gear play .
@Stephen
2 years to the day and i found this thread again .
