wasted wages
1 ton status
Well.......here we go....
I Decided on the Doubler....
Chris and the gang at ORD hooked me up...
Thanks Guys !!!
400 / 208 Adapter plate / Range box / doubler / 205 input shaft /205 twin stick shift rail kit / triple sticks /gasket set....
Main reasons...cheap reliable strong parts....pretty much available anywhere.
The aftermarket boxes appealed to me for simplicity of installation, but I have a fear that if there is a problem with the box,
and the manufacture is going out of business / closed / revising the design, you pretty much stuck with what you have...and the average Joe has no clout when it comes to getting things repaired / replaced under warranty.
Just the pirate link with the problems in the Stak boxes was enough to scare me off of that idea..http://www.pirate4x4.com/forum/showthread.php?t=764135&highlight=stak
In the long run...it will be more work, but I feel confident that this was the right choice overall....Those nice machined aluminum boxes sure look sexy...but what good are they if they won't stay engaged....
I'll try to update this post as I do the install.....not a build thread..
just a time line to kinda keep up with the progress and issues that I come up against....
First thing....pull the T-400/205....The high dollar TCI torque converter (2200 RPM stall w/ anti ballooning plate) I have in the buggy has a tiny weld leak....and slings fluid all over the place...might as well pull the whole thing and do it right....
which brings up another question.....with the lower gearing...is a high stall converter really needed ?
I put it in a long time ago when the engine was supercharged and played in the mud.....I would think it would do better now with a stock stall converter..
Thanks Guys !!!400 / 208 Adapter plate / Range box / doubler / 205 input shaft /205 twin stick shift rail kit / triple sticks /gasket set....
