10-4, I have never messed with the pf-4. Just noticed it. I would double check all your settings. Is the afr stuck at 11 all the time?Just reloaded the map it’s the default
Shouldn’t make a huge difference at idle, but filter could be plugged if it’s supposed to be 58psiHis fuel pressure seems low to me. Mine never drops below 47.
Yes when it’s working right then all of a sudden it takes off and no matter which way I turn the adjustment it doesn’t recognize it .Which map? And did you get the IAC and idle set correctly
Yes when it’s working right then all of a sudden it takes off and no matter which way I turn the adjustment it doesn’t recognize it the map is 5017.Which map? And did you get the IAC and idle set correctly
I have a few times now . Runs great for awhile I’d say 5min or so then all of a sudden it takes a hard right lol . Timing is 12* before TDC IAC between 5 and 15 %Back up and redo the procedure exactly as the manual states. If you try to do it outside the IAC set portion of the program, you’ll just piss it off
Definitely rich where should I start ?The computer is adding and subtracting timing, so when you unlock it and relock it, it’s pissing it off. Set it and leave it
Next thing to look at is why the file trim is -30 and the AFR is 11 something. Should smell rich if it’s that high
The hard right is probably when it’s trying to sort the idle vs AFR. It should be able to stay near 13.5:1 for idle
Comes in at about 50psi then drops fast to about 15psihe’s using an adjustable FPR aren’t you too?
@Chevk587 have you cycled the key on watching the fuel pressure reading?
My go to is fuel filter. Every time I’ve had a Hiccup with mine that fixed it right up. But your could be o2 sensor. Just my .02 cents but I’d swap fuel filter. See what
there is a small leak on the passenger side would that effect it ? Brand new filter.Have an open exhaust or a leak on the bank with the O2? It may be adding fuel to try to burn oxygen not being introduced through the throttle body
Time outComes in at about 50psi then drops fast to about 15psi
