And it went from -30 to 0 on the trim. I’d check the O2 function next
Which map? And did you get the IAC and idle set correctly
Yes when it’s working right then all of a sudden it takes off and no matter which way I turn the adjustment it doesn’t recognize it .
Back up and redo the procedure exactly as the manual states. If you try to do it outside the IAC set portion of the program, you’ll just piss it off
Yes when it’s working right then all of a sudden it takes off and no matter which way I turn the adjustment it doesn’t recognize it the map is 5017.
You should set that timing and then stop messing with it
Seems like it’s happier though
I have a few times now . Runs great for awhile I’d say 5min or so then all of a sudden it takes a hard right lol . Timing is 12* before TDC IAC between 5 and 15 %
The computer is adding and subtracting timing, so when you unlock it and relock it, it’s pissing it off. Set it and leave it
Next thing to look at is why the fuel trim is -30 and the AFR is 11 something. Should smell rich if it’s that high
The hard right is probably when it’s trying to sort the idle vs AFR. It should be able to stay near 13.5:1 for idle
Next thing to look at is why the file trim is -30 and the AFR is 11 something. Should smell rich if it’s that high
Definitely rich where should I start ?
Have an open exhaust or a leak on the bank with the O2? It may be adding fuel to try to burn oxygen not being introduced through the throttle body
My go to is fuel filter. Every time I’ve had a Hiccup with mine that fixed it right up. But your could be o2 sensor. Just my .02 cents but I’d swap fuel filter. See what happens.
there is a small leak on the passenger side would that effect it ? Brand new filter.
Missed that. May have had a drink or two. I’m no help. Carry on. HaHa.
