SOLVED:
https://ck5.com/forums/threads/edelbrock-proflo-4.335548/post-4222806
I fixed the above problem with new spark plugs. Dirty oil burning engine fouls plugs quick.
However, I've been sitting on my current issue waiting to see how it's resolved, but I need to get it off my chest.
The PF4 started giving wonky TPS readings. Some times I would start the truck and it would read 0% or 1%, then then next time I let off the throttle it would be reading anywhere from 3% to as high as 10%. Other times it would read super high TPS as soon as I started the engine. Sometimes it would "fix" itself during the drive, but most times it would stay wrong. It was off by the same percentage across the band. So if it was reading 5% at idle, it would be reading 5% higher at all throttle positions for a given speed. Ironically I had been watching my TPS during cruising to see if I could use that to improve fuel economy. So I knew what the normal readings should have been for say 65mph.
I checked the linkage multiple times and even if the TPS was reading 10% at idle, the throttle linkage as against the stop. I even bought a new TPS sensor and thru that process I learned that resetting everything would fix the problem for about a week and then it would start acting up again. I had the same experience by resetting the ECU and rerunning the setup wizard. But eventually even those short fixes stopped working for much more than 1 drive.
At first it seems like having the TPS wrong shouldn't be that big of a deal. The engine still seemed to be running fine. The problem was because the ECU saw TPS over 2%, it thought I was driving down the road and the IAC wasn't doing anything to help maintain idle. My idle speed was based off whatever position the IAC happened to be in. I found this interesting because on the Holley system, it parks the IAC at 20% when throttle position is above 2%. However the PF4 doesn't ever seem to park the IAC. During my troubles, most of the time it was at 40% to 60%. That meant I was idling at some stupid high idle. Eventually the IAC would meander its way down sometimes as far as 0% in which case it barely idled. I had to open the throttle blades a little extra to make sure it would idle when the IAC dropped to the single digits. Of course that just led to an even higher idle speed when the IAC was further open.
I contacted tech support with some videos showing what was going on. They had me do some things. They had me completely disconnected the trans kickdown, replaced the TPS again, diconnected the Banks iDash, and wired in a new switch on the dash from the battery to the pink wire on the ECU harness. In regards to the switch, tech told me that sometimes the power wire that used to feed the HEI can hold residual voltage after you turn the key off and not allow the system to shutdown properly. They also had me do some other basic things like making sure I could feel/hear the power relay clicking open within 15 seconds of turning the key off.
I knew I was just checking off some troubleshooting boxes and didn't hold out much hope. Nothing I tried made any difference. Finally they told me I had to ship my throttle body and ECU to their electronics department. It arrived at their facility on October 13th. I gave them a couple of weeks and didn't hear anything so I contacted tech and they told me Edelbrock has moved that particular department to another state and my stuff would be forwarded on to them. Okay, I guess I need to be patient. I contacted them again Monday and come to find out not only did the department relocate, but it's an entire new person that needs to go thru training and in the meantime also set up the testing lab. They have no certain idea when it might get tested, but the best estimate is 6 to 8 weeks. He warned me it could take longer because my issue is an odd one.
So I guess I wait to see what the results are. At this point I wouldn't rate the service as good. I really won't know for certain how I feel about it until I get a final resolution. I feel a little like I'm a chump and if I'm honest I feel like they figure it's my fault something is wrong with the PF4. When I talked to them this last time, I didn't get a warm fuzzy supportive vibe. Hell, maybe I did do something to it, but it'd sure be nice to know that so I could rectify the situation. Even if it means I have to buy a new ECU or something. But I would think if I can get the much maligned Sniper to run well, then I must not be too much of a hack.
SOLUTION FOUND. READ HERE:
