CK5 Network
Repairing, restoring or modifying your ride just got a whole lot easier!
Rcundergrounder
Registered Member
Premium Member
Netherlands
Thanks I was just playing with the idea of building a 383 engine.
So figuring out al components.
It will be run mostly on propane because of the fuel cost but I would like to be able to switch to petrol If there is no propane station around.
So when switching fuel I need to load another map with the android app?
Bent77
curmudgeon Status
Staff member
Moderator
Nunya
Yes, and it’s fairly easy. It will store the other tune
a propane plate over the plenum might be the easiest
Rcundergrounder
Registered Member
Premium Member
Netherlands
I have currently a 305 engine with a impco 300 vaporizer unit on top of my edelbrock 1405 carb .
I still have to adjust it properly as with a cold engine it won't start on the propane, so before shutting down I have to switch over to petrol.
When building a new engine with fuel injection I want the propane to be injected as well for better starting, fuel consumption and automatic tuning by the proflo 4 unit ,which won't work when you use a vaporizer on top.
mrk5
The Sticker Guy
Moderator
Vendor
Author
Northern Colorado
Over 3 months Edelbrock has had my throttle body and ECU, still no word. Tried email Monday, but haven't received a reply yet. So far with past emails they've called me back, but it doesn't usually take this long.
I did get a phone call from them out of the blue shortly before Christmas. Imagine my excitement when "Edelbrock" came up on the caller ID. But alas they were calling because they had some parts come in for warranty with no contact information provided. All they had was the return address so they were calling everyone in their system to check to see which contact info went with that address. I must say that doesn't give me a warm and fuzzy feeling about how they handle this type of warranty work.
The guy I talked to did say Edelbrock had contracted with a third party to help work thru some of the warranty returns. He thought that would lead to me getting an answer back in the near future. Don't think that is panning out. At this point I'm thinking either they have a cluster fck over there or there must be a lot of warranty returns to work thru.
Bent77
curmudgeon Status
Staff member
Moderator
Nunya
Probably some of both. Sorry for the struggles
folkenheath
Volcano Manifolds
Vendor
Author
Wisconsin
So it appears due to shortages all future ProFlo4 kits will ship without a tablet, as they can't get them.
The good news is they finished the Apple version of the app, so the apple phones can finally work with the PF4 as well if you download the app from your iPhone or tablet. So most won't need a tablet to set it up now.
mrk5
The Sticker Guy
Moderator
Vendor
Author
Northern Colorado
I should post the update/solution to my woes with the TPS erroneous readings.
@folkenheath was able to shake loose some action from Edelbrock - a good reason to buy from a vendor here on CK5. The sent me a new ECU and throttle body. However after all that, I started to once again have the TPS reading 10 to 14 percent sitting at idle before ever touching the pedal.
I started thinking of all the things that could affect voltage in the EFI system. One thing occurred to me. I have the fuel pump power directly off the harness. Edelbrock states in the installation instructions that you can do this as long as the pump draws less than 10 amps. I specifically purchased a pump from Edelbrock that would meet the requirement. I figured since everything else had failed to fix the problem, it was worth seeing what would happen if I put the fuel pump on a relay.
I drove the truck for 2 weeks and have not had a problem with the TPS. I'm pretty confident at this point, putting the pump on a relay solved the problem. I figure it worked okay for the first couple of months and then started causing trouble because the motor in the pump probably wasn't working as efficiently and started pulling enough current to mess with the ECU. It is an external pump so it's more prone to the effects of the environment and doesn't receive the cooling benefits of an in-tank pump.
It still surprises me the Edelbrock tech didn't ask about the fuel pump given all of the other stuff he had me do. But I think a large majority of people probably put a relay in. My line of thinking was that I had bought a specific pump to meet the requirement and adding a relay was just complicating the install and adding another possible failure point. If only I had been able to buy the in-tank sender I needed, I would have definitely put a relay on an in-tank pump.
You know a lot of people will say 99% of the problems people have with any brand's aftermarket EFI is install errors and technically I do fall into that category.
Bent77
curmudgeon Status
Staff member
Moderator
Nunya
Is the software revision able to allow older units to connect to the iPhone?
sweetk30
I build stuff
Premium Member
horseheads , ny 14845
mine is on the shop desk and has a layer of dust on it since i just use my phone anyway . and saves us 100 bucks as the buyer .
folkenheath
Volcano Manifolds
Vendor
Author
Wisconsin
No savings without tablet, Edelbrock has added 10% surcharge to all orders and the price with the tablet will remain the same now, just no tablet.
Part numbers without tablet are discontinued. They said the tablet prices are 3-4x from previous.
I believe the older units should connect to the iPhone via bluetooth as well, but I haven't confirmed that.
Bent77
curmudgeon Status
Staff member
Moderator
Nunya
Anyone here push this system hard?
Like 1.5 hp per cube, or nitrous, or boost?
folkenheath
Volcano Manifolds
Vendor
Author
Wisconsin
Theoretically you could do nitrous with the proflow 4. But you would need a wet system, and you would need your ignition box to retard the timing since the PF4 isn't setup for that, then it could be done. I will have flow charts for my wet nitrous for both carb and EFI pressures to jet accordingly at 6, 43, or 58 psi.
It can do boost, and it can do racy motors, if they fall within the window of one of the "tunes" you can select from the back of the manual.
When it comes to that stuff though, the Holley is infinitely tunable compared to the PF4. Dry nitrous control, boost control, 1056 cells for fuel and timing to adjust, etc.
Bent77
curmudgeon Status
Staff member
Moderator
Nunya
Was curious if anyone here was actively using this system for that, I have some specific questions to ask. So if you have, call me
folkenheath
Volcano Manifolds
Vendor
Author
Wisconsin
I have not, because when it comes to that, I recommend the Holley. The PF4 is a great system, you can't get a quality sequential MPFI system for less cost than the PF4, but when it comes to power adders or tuning hard core stuff, the Holley is just a better tool for the job.
The Edelbrock is not what I consider a 'true" self learning system. It starts with a base tune that you select from a chart that matches your engine combo, and then it can vary that up to a point to compensate, kind of like a factory system with larger learn limits.
The Holley, Fast, etc don't start with a fixed number of tunes to pick from. They start from nearly infinite parameters you enter, create a base map from that, and then can vary it to make up for it. Most of the Holley default learn limits are frequently +/- 100 to 150%, that's a ~300% window, and you could increase that (but I don't recommend it). The Edelbrock is likely +/- 15 - 20%, and you can't change it. This has it's pros and cons. The bad thing is if your engine is out of that window, you have to start over with a different tune and hope its in that window. Most of the time this works. The good thing is, if something goes wrong it won't throw the tune completely out of whack (just 10 - 20%). It's why I recommend turning learning off in the Holley if you have reached a point where it's running great everywhere. You can turn off learning, but leave on closed loop with smaller limits, to compensate for wear and tear, etc. But if you get a big exhaust leak, or a failure of some sort, it won't be trying to learn off incorrect data.
