I will say for the difficulty cold starting, once it's going, it runs flawlessly. On cold mornings with the carb I had to be careful not to push the throttle too quick or it would die. No problems with that using the PF4.
Yes, you can adjust acceleration enrichment based on coolant temp.Sounds like you need to increase the acceleration enrichment for that, can that be increased vs coolant temp with the Edelbrock?
Sorry I use so many different ones I lose track of what you can do with each sometimes. Of course its easy to see when its in front of me.
If not increasing the cold temp fuel enrichment will lessen it because it will have more fuel to be running with at that temp and be less picky with throttle changes.
This morning I might have figured out some of my problem. I thought I had zero'd all of the cold crank modifiers, but it turns out I had some healthy additions on the colder temps. After trying to start it this morning I thought it seemed like it had too much fuel even though I was backing off the cold start enrichment. Thought maybe I needed to mess with cold crank and that's when I found I was still adding fuel at cold temps. Interested to see how it acts tomorrow morning.So far making cold start enrichment changes 1% at a time hasn't helped with my cold start issues. The routine now is to crank then give it a little pedal to keep it idling until the O2 sensor is warm and running in closed loop.
I'm thinking maybe it needs just the right combination of cold start enrichment and crank fuel. It's frustrating to pin down because you don't get any real feedback from the system until the O2 sensor is heated up. Or there is something else causing the trouble. All other operations are basically flawless.
That’s what I figured FML!Need a car tuned port setup if using a pro flo xt setup by the looks of it .
I have the 4150 carb style and clear our truck serp belt stuff just fine .
Yeah sorry, my setup is the same as sweetsThat’s what I figured FML!
