I knew a guy that had a seized up Mazda rotary, he hooked up the starter 24 volts with 2 battery's...that got it spinning!![]()
Yah, don't do that
A rotary would have way less contact points to rust/seize.
Hood was on all I did was drain all oil from engine and trans no air cleaner on headers on but no exhaust plugs were on I took off dizzy to use on another burb but got a new one and put it to tdc about two years ago and that was last time I moved it. So put new wires and dizzy on went to crank and starter just clicked remove starter put new mini high torque starter and same so tried to turn from harmonic balancer nothing tried from flywheel nothing so here I am. Now just letting mmo and atf sit for a few days.
Yah, don't do that
And for sure! not many moving parts on a rotary.
Ok...just kind of surprised it seized up. Hope it works out for you.
I'm also surprised it wont turn over cant think of anything else keeping it from spinning plugs are out serpentine belt is off headers are off sprayed the crap out of cylinders and nothing I dont know letting it sit with mmo and atf the torque converter wouldnt be stuck would it rear tires spin fine and shifts good.![]()
That's what I meant....getting em to run again usually isn't the issue if you free em.. having em last longer than a couple hr's is...![]()
