Entertain Us - 400 sbc question
Bent77
I am CK5
Nunya
Me and @6872xtc get bored and beat topics to death
Our latest is about the actual crank hp an tq ratings of a factory install 400. Not talking sae vs whoever’s mother wanted to rate/rerate
Just actual crank numbers as installed, original manifolds and such, if it were ran on a dyno
So are we looking for someone that has ran one on a dyno or what the factory rated them at?
I'm going with 180 hp SAE net. All accessories, through cast iron manifolds, etc, etc as it was installed in the car. These had shit heads, and weren't designed to be a high performance engine, more of a stepping stone between the regular 350, and the 454 big block.
Think they actually made 400 lb/ft? The 350s used the same cam, and I doubt the low compression ones made 1 per inch there either
Depending on how it was configured I’d guess between 150 - 200hp and around 300 lbft.
Found this on this site. For my truck.
So the book that I remember reading some specs in was an old "Motors" manual. And as I said, it was only the first year, 1970, of the 400 SB that had the torque value close to, or at 400ft/lbs.
Maybe it wasn't 400, can't remember exactly. Still, it was better than the 350 of the same year.
Not that I can remember when the change happened in the rating method back then..
Glad to see the smart-a$$ crew is bored and posting!!!
:flipoff7:
:D
:flipoff7:
:D
Why are you posting here and not somewhere else?
Still stand by the premise that a 350 with a roller cam and 9.5:1 will outpull a stock 400. Not too sure most stock 350s won’t…
It’s not like they had great heads to breath thru
Ands what the bent one is ignoring is I didn't give a crap about the horsepower number, just the torque and the rpm that it peaked at. Midrange torque. Period.
No, they didn't have great heads, but look at the torque numbers and the torque peak rpm of the Olds, Buick and Cadillac engines of the late sixties and 1970.
Got home already.. it is Monday night.
And yes, I agree, up until you talk stock 350 vs stock 400 of the same year. 2500 to 2800 RPM, the 400 will pull a little harder on torque. Wind them both up farther and then the difference goes away.
I had one of theses 400 s in a 72 3/4 ton and I’m sure my 305 would out pull it.
Nah. 400 will run out of air at 3300rpm…
