ezoliver
Mall Crawler
Going to see if I can tackle the front upper shock mounting situation today and tomorrow evening after work. Updates to follow...
BGKYK5 beefed up his Ford shock towers. Might want to check out his build. Believe it was a year or so ago.
Looks good! If you would like someone to store your wheels/tires for you until you finish the build I could arrange that for you.
BTW, do you know how much one of those wheels weighs?
LOL ya I bet you would "store" them!
The wheels themselves are very heavy for an aluminum beadlock, but weigh less then most steel setups... 40 pounds each. They are built for some serious pounding.
Do you know how much comparable aluminum beadlocks weigh in the same size, such as TR beadlocks? I can't find that info anywhere.
No pun intended. I've heard that those will let you air down quick. Can't you set them to where they stop letting air out automatically when they get to a certain PSI? That would be most helpful.I've heard that those will let you air down quick. Can't you set them to where they stop letting air out automatically when they get to a certain PSI? That would be most helpful.
always loved this build....
please finish it for me.
