Finally my 383 build
So I just emailed the service department at Eagle to see what they had to say. They pretty much said the same thing all of you did.
We recommend a minimum of .050" clearance. If you have .035" already, removing a small amount of material from the rods that need it will be fine. You will only affect the weight a couple of grams and that is not enough to make a difference in the balance of the crank.
So I finished grinding the rods last night. I intend to replace all the bearings for peace of mind. I wish I would have saved an old set of bearing but I didn't and I'm not chancing any metal shavings being embedded into the bearing.
I got the bottom end and cam installed. I ordered the Edelbrock 60989 heads last Friday they should be here sometime next week. More pictures to follow.
never built an engine, but I would have thought the valve relief pockets where backwards.
When I think about the heads, aren't the valves on the downward side (meaning opposite side of the intake, nearer the headers) Would have thought that's where the pockets should be. But I googled some short block pictures and saw different.
guess I'm thinking too far away, like the rockers are 4" long :haha::doah:
Good thing you're not building a motor! :haha:
It is well worth the money, especially since theres so much already going into it.
I was intending on having Brian at TBI chips burn a new chip for it. With the data we can capture from the computer he seems to think he can get a pretty good tune.
He comes highly recommended and has been extremely helpful.
Girlfirend says it looks like a bunch of happy faces smiling at you LOL So I guess if they were wrong the motor would frown at you :haha:
I used him for the first chip, but then ended up just buying an autoprom and started burning my own.
I can tune a honda or Acura but when it comes to GM cars I don't know anything about their computers. I understand what is going on but I wouldn't know what values to change to do what.
My understanding is the computers are pretty basic and the inputs are fairly limited. Its only slightly better then running a Carb. Kinda crazy they used this technology up to 97. Brian has been extremely helpful with this project and answered a lot of questions. I'd rather let someone that knows way more then me about tuning GM cars do it. I have no interest in GM beyond this truck anyway :(
I understand, if you change your mind come join us in the TBI section on this site. Mark and Dave are some pretty smart guys when it comes to this stuff.
I bought a programmer and an eraser. So we'll see if I play with it at all after I get the initial tune done.
Intake manifold arrived today just gotta figure out how to plug everything back in and plug the unused holes. I think I'm going to need to drill and tap the temperature sensor port because the one on this intake isn't even drilled out.
My Edelbrock push rods showed up too but one is pretty dinged up and now I will have to wait for a new one.
I havent been following Edelbrock's stuff, but i didnt know they made the intake with the EGR ports right there
