Cutting
So I did a tiny bit of sand blasting today to get rid of the piles of bondo on the floor to find what needed to be cut out and where the seams for the panels were.
The previous owner did a real hack job. Tons of bondo, some weird stuff under the pedals that seemed to be roofing tar or something.... Wouldn't come off with the sand blaster, and too sticky to chisel, so I used an angle grinder. It made a mess but it worked. The weird thing was that it didn't seem to serve any purpose, the metal under it was in decent shape.
The PO replaced the outer rocker it seems at some point. Barely holding together using only tiny pop rivets.... Also higher up on the B pillar was a shoddy weld job for another patch.
It looks like I have my work cut out for me but I've started delving in, sand blasted underneath to find where the good metal still remained and then cut out the drivers side floor panel.
Question: to get to the 4 bolts area/A pillar repairs, I am wondering if it would be easier to cut out a patch on the front fender to make it accessible or if I should just take off the entire fender. I'm not doing a frame off resto, and I don't want to take off stuff I just have to put back on later if I don't have too. Just wondering if someone would have some first hand knowledge of what route might be quicker and easier.... Thanks!
