Flat towing my K5
Im leaning towards just removing the rear shaft completely since I can with the SYE. And was figuring Id be able to unhook from the RV and park the Blazer by locking the hubs, putting it in 4hi and driving it in FWD like you said haha.
You should install the rear drive shaft before you unhook. You will need to have the t case in neutral to line up the shaft with the rear yoke. Yes the parking brake can and should be used, maybe even a wheel chock. If still hooked to coach twice the safety.
That defeats the purpose of driving in fwd to quickly park the rig. Its not like I would ever unhook on uneven ground. My parking brake does work btw. If I lock the hubs and put it in 4wd then I can park with the parking brake and leave the trans in gear. Its the same amount of redundancy as having the rear shaft in with the truck in 2wd. Then when Im parked in a flat level spot I can just use the parking brake, unlock the hubs and put everything in neutral to line up the flange to install the rear shaft. That would be a lot faster to get the toad off the RV and everything parked.
Last I knew in Colorado you're required to have trailer braking system in any trailer over 2,500 lbs. This includes a flat towed vehicle. I'm sure downhill on mountain passes was a big justification for that law.
Used to be a CK5er moved here from AZ that always flat towed his wheeling rig and that rule was something he learned about.
I bet we put 25,000 flat tow miles on a Wrangler behind my parents RV growing up. T-case in neutral and go. Those have full time hubs too. Only trouble was bolts on the tow bar loosening up from road vibration.
On my Deuce and a Half the winch PTO shifter has a little hinged plate next to it with a slot for the shifter. With the plate down it holds the shifter in neutral. Flip the plate up and it can shift normally. Building one similar could be an option to stop an unwanted shift. I don't see how they could pop into gear anyway like some claim.
Pulling the driveshaft is not hard anyway.
My brother has a brake buddy, that he want to get rid of. let me know if your interested, I'll let you 2 hash it out.
I know it’s a few years later, but how’d flat towing work out?
After working out a few kinks it worked great. At first I definitely had too many links in the chain and the blazer would wobble around behind the RV quite a bit. At first, the Blazer would rock back and forth quite a bit. Bad enough that I drove it about 1500 miles on a trip and it badly wore the front tires on the Blazer. Initially, in between the Blazer and RV I had a receiver drop, ready brake and tow bar and the way I had mounted the tow bar to the blazer was not great so there was a ton of play. Once I built a new front bumper for the Blazer I was able to delete the receiver drop which got rid of a fair bit of slop in between the rigs and I was also able to use thicker D-ring mounts so I could ditch the washers I was using previously and that also took out a lot of slop.
The ready brake works really well and is super simple to install and use. The only downside Id say is the brakes/turn signals. Without tapping into the blazers wiring to connect it to the RV there is no easy way to make the blazers tail/brake/turns work so I wound up running a 4 pin trailer harness from the front bumper, along the frame, to the back bumper, plugged it into the RVs plug at the hitch and tossed some magnetic trailer lights on the back bumper of the blazer. Wound up working well and being super simple.
Im actually looking to sell my current tow bar and ready brake setup so I can buy the Ready Brake tow bar that has their brake system built in. This would eliminate yet another link in the chain and make the blazer even more stable when in tow. Ive actually sold the RV and have an Alaskan camper in my Ram now. Not sure how often Ill tow the blazer but Id like to have it as stable as possible behind the truck because its lighter than the RV was. Although maybe not by much when the camper is in the back haha.
I wound up pulling the rear driveshaft every time just to be extra safe with my transfer case. Got to the point where it was only about 10 minutes to install/remove the shaft.
