Yeah. I think I am actually going to go back so I can use the stock bottom mounts at the correct angle. Going to try and basically get the same angle as the factory rear mount. Started grinding out the rivets last night and plan to reinforce with 2x6 "L" steel. May do the set back trick like BGKYK5 if appropriate.
BTW, factory rivets are way more of a pain than I expected. Ground the head off and could not punch it out until I got out the air chisel.
