Gallons Per Mile, Post up or die!
1983 Chevy K-10 /forums/images/graemlins/truck.gif
350CUI Gm Performance Parts Crate motor
8* BTDC
600 cfm Holley
14x4 Open element Wix Air Filter
Run 89 o-tang
Unknown mileage on truck. The Odometer has been stuck at 42K since i bought it.
10K miles on engine
TH350 unknown miles, not stock
NP208
No rebuild as far as I know
Front 8 lug 44 and rear 14bFF
4.10, open carriers.
6 in Lift, 4 in rear springs with 2in blocks
35x12.50x15 Pro Comp mud terrain on road
36x14.50x16.5 Tsl Radials offroad
12mpg city
14mpg highway
1984 K5
305cid stock from a 1987 but, with q-carb on it.
stock drivetrain
4" lift
35x12.50x15 m/ts
10-12mpg at 70mph
1990 V2500 suburban
454 with a few mods
TH400 with full reverse manual valve body & 2200 stall
Np205 transfer case
Dana 60 5.13 with detroit, 14 ff 5.13 with detroit
HAD driveshafts front and rear
12" suspension 1" zero front
6" spring 1" zero rate ,ord shackle flip
3" body lift bushwacker cutouts
44"x19.5"x16.5" boggers on 16.5"x12" weld outbacks
8 mpgs /forums/images/graemlins/woot.gif
350 bored .060-3000miles on rebuild
Comp cam High Energy 268H
Jet Perf. Qjet
Timing set for best performance >12*
Edelbrock Performer intake
MSD Pro-Billet Dist
Thorley Tri-Y's
Dual 2.5"
Flowmaster Super40's
TH400 tranny
NP208 tcase
3.08 gears
33s
10mpg anytime I've tracked it, pop-up camper or not.
All my vehicles specs are in my signature,so I wont repeat them to save space--only change is my 79 C10 now has a 305-V8 instead of the 250 camelhumper six(RIP /forums/images/graemlins/frown.gif)----it gets about 2-3 mpg more than the six did(!),between 14-17 mpg in normal city/highway driving.
My van gets about the same,13-17 mpg--but its been parked since last christmas--so I guess it gets 1000 mpg when it doesnt move!
The 74 K20 only gets 8-13 mpg,empty or overloaded--it had a 454 before the 400 small block in it now,actually got a little better mileage with the 454 by 2 or 3 mpg--it would consume about 5 or 6 gallons an hour when plowing!.
The 82 K20 diesel is the mileage king--it gets between 15-22 mpg,has plenty of tourque,pushes snow like it was a bulldozer,and you can climb right up the snowbanks at a 45 degree angle with no flodding,stalling or other annoying carb related issues(the AFB on the other K20 makes it hard to do hills or off camber angles--starts crapping out almost as soon as its no longer level!)--I think I like the diesel best--except for the smell and additional noise(I dont mind it much--but the members of the fairer sex sometimes dont like it--some girls love the machoness of a diesel--others hate it!)the only downside is its now 2.15 a gallon for fuel(as of today at least--I should fill it up--I waited a week to see if it would drop and it went up 25 cents a gallon! /forums/images/graemlins/doah.gif /forums/images/graemlins/angryfire.gif).
How much are they raping you guys for diesel fuel and gasoline where you are??--I see gas is up to 1.99 around here for no name sub-regular skunk piss,diesel ranges from 2.15 to 2.29 a gallon,seems to go up every day.Looks like its going to be a rough winter for me this year--later today I'm going to go get some firewood--I use it in my shop mostly,but this year I might have to use the wood stoves in the house too--havent used them since the oil embargo of the late 70's,but I've kept them up to snuff in case of power failures to keep the pipes from freezing!. /forums/images/graemlins/crazy.gif
76 K5 Blazer. 6" lift, other then that, all stock. Carb needs rebuilt, MPG's ?? Unimportent, it's a fun vehicle, and well worth it. If I knew for sure, I'd leave it parked, oh wait, I've done that anyways for the most part.
90 K5
350 TBI Stock
45,000 on rebuild
200,000 miles
700R4
241
10bolts 3.73 open
6" TC lift
35s
arround 14-16 highway
8-10 city
oh and I like the skinny peadal
1971 GMC Suburban
388 CID Small Block Chevy...all stock /forums/images/graemlins/rotfl.gif
Summit HEI & MSD 6AL
Holley 3310....soon to have a Q-jet built/tweaked by me
Perf RPM intake
14x4" K&N open element
Hedmans with 2.5/3" exhaust & 40 series Flowmasters
TH350 rebuilt by me
2000 RPM Stall
NP205 T-case Untouched
Stock d-shafts
D44/14BFF 4.10 open/open /forums/images/graemlins/doah.gif
35" MT/R's on 15x10 wheels
I get about 8-11 mpg depending on what I am doing. /forums/images/graemlins/waytogo.gif
I had a 71 burb 4x4 for parts,the side rear windows are still leaning up against the tree I put them there over 10 years ago! /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif Got Glass???.I have some interior parts too--mine never made it to the street,too rusty,so I parted it out--I hated to cut it up,it was a cool truck!.I'd love to find an older suburban panel truck 4x4 again,expecially the 55-66 ones--the coolest looking trucks GM made in my opinion,the 67-72's are pretty nice rigs too.Too bad you cant walk into your local GM dealer and buy one today,with the old body style and todays technology under the hood!. /forums/images/graemlins/crazy.gif
89 3/4 p/u
383 TBI(stock injection set-up /forums/images/graemlins/frown.gif ) Very high comp.
20-30K on rebuild
700r4 built
20-30k on rebuild
241 stock
4.10's
timing - /forums/images/graemlins/dunno.gif It's retarded though.
Gas - have to run 93+ and usually a mix of Turbo Blue so it wont ping /forums/images/graemlins/frown.gif
35x12.50x15 BFG AT's on stock SA steelies
6.5 MPG around town.
87k5, 5.7TBI, 700R4, 3.73 with 35x12.5" BFG Mt's on Aluminum rims- Got 16ish MPG over 800 miles on the highway at 65mph. (yes, thats calculated via GPS and fuel log).
92 6.2 2500 ext cab long bed- High of 22.5, but low of about 16. Depends on speed. 265 tires. 4.10 gears, nv4500.
My old DD...
1997 Tahoe 4dr
Vortec 350/4l60
Mixed driving
Heavy Foot
33"
2" lift
Dual straight exhausts (after cats)
3.73's
9.6 mpg /forums/images/graemlins/angryfire.gif
Stock 1990 1/2 ton suburban
350 TBI
32" BFG AT/KO
38,0000 miles
15-16 mpg mixed city/highway
/forums/images/graemlins/weld.gif /forums/images/graemlins/eek.gif
1982 Chevy F/S Blazer
397 CUI 6.5L Diesel
stock Air Filter
Run Diesel fuel, of course!.
175,000K
Motor swapped in 40K ago /forums/images/graemlins/tongue.gif
TH700R4
NP208
Front and rear 10b
3.42s, open carriers. /forums/images/graemlins/doah.gif
3.5" Lift, hacked fenders
33x12.50x15 BFG AT'S
No doors, no back cab roof, no backseat, no rear bumper, heavy ass diesel, 2 batteries, tools/gear.
Roughly, around 14mpg, with underpowered gears.. need 4.10s (soon to come)
/forums/images/graemlins/k5.gif
1987 3/4 ton 4wd
4" susp 2" body lift
35x14.5 SSR's
Run Shell or Hess 93
496MPFI w/ 9.7:1 compression/th400/np208
4.10 gears
timing I dont remember
get between 10 & 12mpg everywhere
1991 Chevy V3500 Crew Cab
350 CID
Fuel System: TBI
0* BTDC
closed element air filter
Run 87 o-tang
120k on truck
Trans: 4L80E
120k on motor
Transfer Case: NP205
4" suspention lift
1" Body Lift
Front Dana 60, rear 14 Bolt FF
4.11 Detroit Locker rear, open front
35x12.50x16 Pro Comp MT
12 MPG
350 CID
Fuel System: TBI
0* BTDC
Run 87 o-tang
120k on truck
Trans: 4L80E
120k on motor
4" suspention lift
1" Body Lift
12 MPG
You're doing better than me...
1991 V3500 crew cab SRW (see sig for specs)
170k
89 octane
I get a crispy 8~10 around town. /forums/images/graemlins/doah.gif
