Gallons Per Mile, Post up or die!
[ QUOTE ]
[ QUOTE ]
[ QUOTE ]
... I am getting better at reading the cryptic signatures....
[/ QUOTE ]
350QKN70020845635:11 /forums/images/graemlins/tongue.gif /forums/images/graemlins/cool.gif
[/ QUOTE ]
350 w/ quadrajet
K&N(crap)
TH700R4
NP208
4563???
5.11's maybe...? /forums/images/graemlins/1zhelp.gif
[/ QUOTE ]
how about
350 w/ quadrajet
K&N
TH700R4
NP208
4.56
35"
11mpg
[ QUOTE ]
[ QUOTE ]
The 6.2 wasn't much in the go department, but got the gas millage.
I always wondered why more people don't run diesels off road. Easier to water proof, and torque!!!
[/ QUOTE ]
Plus weight, smell, mess (common), and noise. /forums/images/graemlins/laugh.gif But I gotta say, Rene's was nicely done and I had no problems with it on the trail (smell, noise, etc.). It worked very well IMO. If I were doing a daily driver with mpg and longevity concerns with solid off-road capability, I would probably be looking for a turbo 6.2/6.5.
[/ QUOTE ]
Thanks Russ, I thought it worked exceptionally well in comparison to the old carb'd 350 I pulled out. With the 4 gear it seems to make more than enough power for me even with the 40's...but a turbo would be cool and is something I'll add eventually.
It's no messier than my 350 was...actually it leaks quite a bit less. /forums/images/graemlins/tongue.gif Noise only really becomes and issue on the freeway...on the trail it's plenty quiet. Weight is on par with a big block. Smell would be an issue with badly routed exhaust, I rarely if ever smell diesel exhaust in the truck.
For me the diesel made the most sense. Good fuel mileage, decent driveability, inexpensive to buy, great offroad. Ideal for a multi-purpose truck.
Rene
[ QUOTE ]
soft top
[/ QUOTE ]
Can-back top here.
Me, my girl, and my mom is behind my girl. Can back bling-blingin!!
That was a nice 87 1-ton dually with an 8' wide dump body.
Can back down. What do you think of the "N" tree?
But I don't think it changed my gas mileage, wasn't that one of the rules??? /forums/images/graemlins/rotfl.gif
[ QUOTE ]
[ QUOTE ]
[ QUOTE ]
[ QUOTE ]
[/ QUOTE ]
[/ QUOTE ]
350 w/ quadrajet
K&N(crap)
TH700R4
NP208
4563???
[/ QUOTE ]
how about
350 w/ quadrajet
K&N
TH700R4
NP208
4.56
35"
11mpg
[/ QUOTE ]
Yup; just couldn't resist. Rebuilt 350 with vortec heads (57k miles on bottom end, 20k miles on top end); stock cam, timing at 8 degrees; Carb jetted down (from 72 to 70); Carb spacer and K&N (for filtering properties, not for power/mileage - check my website); headers; new cat; single 2.5" exhaust; 3" lift, 10-bolt/D60 rear w/ 4.56 gears; 315/75x16 MTRs (radials, they measure 34.5" w/o load); average 11mpg fully loaded (w/ 'cage and back seat and spare parts and tools and Hi-lift and CO2 tank and fluids and what have you). Empty, mileage is 12; both numbers corrected for speedo error.
1985 GMC Jimmy
350CUI crate engine
Run 89 gas most of the time, sometimes the cheap stuff
miles? i have no idea, i dont have a working speedo/odo That said, probably less than 10k on this motor.
TH700R4
np205
ff14 + D60
4.56 gears + detroits
39.5x15x15 TSLs
based on how much gas I put in it, and how far I drive on trips, I probably get between 8-10 mpg.
j
[ QUOTE ]
[/ QUOTE ]
What do they filter? Boulders? Aren't rock sliders for that?
There Kaaaaaaaaayyyyyyy-RAP! /forums/images/graemlins/thumb.gif
[ QUOTE ]
[/ QUOTE ]
Pretty sure I read tha 'paper filters' filter better than a K&N...no link to back it up though.
Rene
That is true and it's been proven in several tests. K&N is not only crap, it's over priced crap that flows *very slightly* better than the average paper filter, but lets WAY more junk through. Its only real benefit is in its ability to continue working while wet, and if it's wet, well then you likely have other issues. K&N is all about image and hype...
YES YES YES
***THE***
***FIRST***
***ONE***
***WHO***
***AGREES/KNOWS***
Even steve says he's running one. /forums/images/graemlins/confused.gif
His poor 1991 K5!!! /forums/images/graemlins/1zhelp.gif
Might just as well /forums/images/graemlins/grind.gif on your cylender walls, or pour sand in your crank case. Pour sugar in your gas tank, and stuff a potato in your exhaust.
Then drive it up a light pole and get UNDER THE TRUCK AND PRETEND TO BE BUDA. /forums/images/graemlins/ignore.gif
Not good. /forums/images/graemlins/frown.gif
305
Qjet
Th350
3.08's (maybe lower??)
dual 2.25" with headers
edelbrock intake
stock cam/pistons/crank
33" Geolanders
needs timed (usually runs at 14*)
I get about 12MPG in standard gallons....so REALLY bad in US gallons... /forums/images/graemlins/eek.gif
1975 Chevy K5 /forums/images/graemlins/k5.gif
350CUI Q-jet carb (Rebuilt by the Carbfather, AKA dad)
10* BTDC (higher altitude in CO)
14" open element on handmade velocity stack
Run 85 octane swill
MSD super HEI distibutator
Unknown brand headers with 2" dual exhaust w/ h-pipe and cherry bomb mufflers (to be replaced with turbos soon!)
Unknown mileage on engine (used, but not used up-no smoke)
SM465
NP205
Front D44 and rear 12b
3.73, open carriers.
33x12.50x15 Kellys (OLD and dry!)
Speedo is off, but I manage to pull 7 mpg on a bad day, 9 on a good one! Sure could use an OD, but I love my granny gear on the trail.
[ QUOTE ]
How can you have a quadrajet (nice off-road & onroad carb) and TPi? I can't remember what it stands for exactly, but I'm about 90% sure it's a form of fuel inFection...
[/ QUOTE ]
Sorry guess I wasnt specific enough. Thats the specs of the engine when it got 12 MPG. I now have TPI (Tuned Port Injection) but dont know the mileage, obviously better.
[ QUOTE ]
What about those new air hog filters??? Same thing as K&N??
[/ QUOTE ]
I would put one of those on. Havent you seen the commercials? Those hogs look mean, I wouldnt want them comingout fron under my hood!?!?!? /forums/images/graemlins/yikes.gif
/forums/images/graemlins/histerical.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/rotfl.gif
6.5 mpg Highway towing or not.
1981 SRW 1-ton Crew cab 4x4.
454, Edelbrock 625cfm carb, Performer intake, headers.
Timing set by ear. /forums/images/graemlins/whistling.gif
SM465 and NP205
4.10 gears in a Dana 60 and 14 bolt
35" BFG Mud Terrains
Wind catching devices including front mounted winch, bug shield, and light bar with 5 lights sitting atop the cab.
'90 Blazer 350 TBI
MSD Dist.
MSD 6A
40,000 on rebuilt motor
200,000 on truck
stock 10b f/r 3.42
31X10.5X15
no lift
14 city/ 17 hwy
1987 K5
Built TBI 454 (.030" over, FT's, etc)
sm465/205
D60/14bff with 4.56's
37" MTRs
6" of lift
~7mpg in town (the way I drive)
~12 on the Highway
Chris /forums/images/graemlins/whistling.gif
84 K10 shortbox
Had 4 or 5 different engines
Had a 700R4, now SM 465 with hydro clutch
Had 208, now 205
Had 10s, had a 10/12 combo, had 10/14 SF combo, now 60/14 bolt
Had 31s, 33s, 35s, and now 38.5s
ALWAYS got 11 MPG from day one.
89 Suburban
350 TBI
TBI spacer and injector spacer
700R4 / 241
with 10/14FF / 4.56
39" tires
12" suspension
11-13 mpg
