Mine are about there. Screw double nuts, buy a bunch of the right bolts, and tack weld the nuts in place.
this is the best/ cheapest and easiest option yet. With my rig having a boxed frame and these should help out a ton hopefully. Im not going to run another hanger as the exhaust will be solid to the frame the rest of the way back.
you can see them in this pic, flex couplers.
. There's no fuse in the starter wire so it melted the terminal out of the battery. Had to get it towed home. Got it all fixed, but had to buy a new battery. I feel like a dope for not checking ahead of time. Just a common-sense warning for others.
