Help me INSTALL a big block...Bought a 468!
Not sure what the lobe seperation is but I'd say a hydroboost is in order
That's probably a little too much cam for what we do, but I'd run it, you'll be fine with the manual
definitely get a stronger fly wheel, they can explode and ruin things
I'd have no problem turning that engine to 7000 rpm, I'm actually pretty jealous that you have that ability :whistle:
Is it a 454, I missed the cubic inch part
Heres the cam I'm running and the vacuum booster is right on edge with not having enough vacuum
I doubt you have a LSA close to mine so you'll not make enough vacuum
My truck runs great and handle idled and low rpm's all day when I went trail riding, EFI is definitely on the list though
DURATION .050: 231 236
LOBE SEPARATION: 114 114
ADVERTISED DURATION: .006 291 296
GROSS VALVE LIFT: 597 613
It's a 468 (454 .030 over) full roller. I already have hydroboost, so I'm good on that front.
You guys need to help me compile a list of crap to order from summit so I only have to go up there once! Here's what I need so far:
-water pump/t-stat and waterneck
-hoses?
-distributor/wires/plugs (has marine plugs in it)
-flywheel (gonna need a recommendation here because it's internally balanced)
-Headers
-oil pan/pump/pickup
-valve covers (the ones that came with it were clearanced with a hammer to fit in the boat)
-Fuel pump
-timing light (don't have one, in Germany or here)
Anyone know what kind of timing I should start with on this thing?
I'm going to keep the carb now and see how it does. If I choose to go EFI in the future it'll be a bolt on swap like the FAST system. Do I need a larger fuel line? My buddy thinks I'll be fine, but I figured I'd ask. I'm planning to NOT do a fuel cell for now just to save some coin at the moment. I wouldn't feel so bad about it except I haven't sold any of my small block stuff yet and would like to hold off on unnecessary spending until that stuff is gone.
Also, I need accessories for the front of it and was wondering if the TPI serp setup will work with a big block? I doubt it but I thought I might ask. If not I'll probably try to source some on craigslist. If that doesn't work I'll just get brackets from scummit and change out the pulley on my PS pump and rock v-belts. I'm not dropping the coin for a march serp setup. Unless of course I find one on summit's clearance racks...
I'm beyond giddy. Probably won't be able to sleep tonight:haha: Been wondering all day what the weak link in my drivetrain is now??? I guess I'll find out soon enough:whistle::doah:
Pssst...454 bored .030 over is a 461.
Seriously awesome find though :woot: Nobody has mentioned the work you may need to do on the firewall to clear the distributor and valve covers.
Yeah, I know about that... I have my engine / tranny moved forward 2",so hopefully it's minor...
Then what makes a 468?! That's what everyone is calling it. I just don't know if a 461 is enough cubes... :D
OK good on the firewall. The firewall and the headers are where all the clearance problems are on ours.
.060 over gives you 468. burnout
Gotcha!
I'll be calling Kert today for taller motor mounts and I've got the part # for the headers mike has. Hopefully everything else is easy enough to deal with!
Buy the Kwik Performance adapters and you can use your SBC serpentine setup on that BBC.
Martin
Martin
Saw those while googling things last night. There's a local yard I'm going to check with tonight that might have a stock BBC serp setup that I can buy for less than those adapters. Otherwise I'll look into the Kwik Performance stuff.
Any reason I shouldn't go this route?
http://www.summitracing.com/parts/sum-csum2751/overview/make/chevrolet
The MSD stuff is significantly more expensive... If it's not recommended, please link me to what I should be running.
Already have $870 in my shopping cart on summit.com and don't have ignition/plugs/wires in there or my belt driven accessories yet:doah:
I need to get the small block stuff I have out of here and freshen up the wallet a bit:haha:
Already talked to Kert today too and got my motor mounts ordered. Getting there!
Why wouldn't it? Unless it's an electronic advance EFI unit.
Martin
Sean I added what I used as best I can remember!
-water pump/t-stat and waterneck...stock type iron pump, reverse rotation for serp setup, angled thermo housing worked for my application, and 180* stat.
-hoses? I used good brand (gates?) rubber hose for heater hoses
-distributor/wires/plugs (has marine plugs in it) check w/ head manufacturer for plug usage....I used Taylor 135* wires which clear the headers really well
-flywheel (gonna need a recommendation here because it's internally balanced) I believe you can use a neutral balance flywheel, as the present assy is probably already balanced w/ the existing flywheel in the engine video. Call a competent machine shop to be sure.
-Headers I used L&L, but I don't think they will work for your chassis??? long tubes=more torque, but clearance has to be considered as well.
-oil pan/pump/pickup I used stock 6 qt pan, fit my needs well, a Melling hp pump is the only oil system change I added, Chevy's have a pretty good oil system stock.
-valve covers (the ones that came with it were clearanced with a hammer to fit in the boat) I like cast alum, for superior sealing. go with what fits your truck...watch Ebay I picked up my Comp Cams for 100$ /pr.
-Fuel pump If your thinking FI in the future might as well plan on that right now into your fuel system...although if your running a carb for now, you may have to change to another pump for a FI unit needs. Run a Holley blue w/ regulator for a carbd app.
-timing light (don't have one, in Germany or here) I have an old Craftsman light I've had forever....if you have a timing tape on the balancer, go with a basic clamp on wire type light, if not get a decent dial back light so you can see what your advance curve and total advance it doing.
Alot of opinions for this, but I would shoot for 12-14 base at idle, I wouldn't even worry about vac advance on this engine....shoot for a relatively modest advance curve to bring it up to 32* by 3000 rpm and total no more than 34*....you will have to see what your vehicle and engine combo like when you get it going, but those should be safe numbers to start with, you may be able to get up to 36-38 if that engine likes it.
A healthy BBC like this could use a 1/2" id line for higher rpm stuff....carbed engines tend to need bigger feed line than a FI engine because of pressure from the pump. Drag racers use up to -10 for a feed line on a stout BBC, I would think you'll be ok with -8 unless you run sustained high rpm. Keep in mind the future of EFI...I'm using my old 1/2 line to feed front to back, and adapting to it at each end for the EFI.
A pic of my junk for reference:
Given my current focus on my 383 I'm interested in your fast EFI stuff. I think SBD said something first, but put me on the list. :pimp:
