dmcx72
Iron horses in thin air and thick.
With a good quality spot-weld cutting bit and about 1 hour's work you could remove the dual-headlight setup from the original core support and move it over to the new repo core support (of course you'll also need to remove the single headlight basket from the new part)...
I doubt you'd be able to do all the necessary rust repair on the original core support in less time, and you're going to be out the shipping and re-stocking fees for the repro part if you send it back too. I'd make an attempt to use it if it were my project....
lightly sand around the mounting flanges of those headlamp buckets and locate all the "dimpled" spots where the factory spotwelds are. Cut them carefully and those old buckets will lift right off!!!
Guess I'll give it a go. Any chance you've got a link or some place I could get instruction on using one of those bits?
Just answered my own question:
http://www.youtube.com/watch?v=PfY3tbRJ9qU&NR=1&feature=fvwp
And I don't have a spot welder either ... I'm starting to think body shop. Too bad I'm such a noob and in a hurry to get it together before I move from Louisiana to California (in 1 month!)
Where in CA did you move to?
