Two options come to mind:...the exhaust pipe outlet will stick straight out towards the inner fender or tire!
- Wait for a 6.5 or Banks manifold
- Fab up some 180* headers and a bundle of snakes
Found a 6.5 turbo manifold on eBay for 99$ taking the easy route..
Might be easy, but at least you can sell it when it goes poofFound a 6.5 turbo manifold on eBay for 99$ taking the easy route..
I have a 6.5 turbine setup I might sell...
The voice of reason got the best of me.. while a bundle of snakes would be cool and the hotrod in me wants to know what that would sound like.. I'm taking the well traveled route.. it works for lots of guys alreadyTwo options come to mind:
David
I have the holset turbo I am going to use but thank you.Which Holset are you using?
Thanks David, your right and I also have 2x trucks being linked this month, so to say I am busy is an understatement. I don't want to rush and create problems but I also don't have any time that I can really "waste" on fabrication if I can readily purchase the parts for cheap.. ironically the guy I just bought that exhaust from has 3 other 6.5 diesels so I am going to buy the intake manifold and plenum as well if he lets it go reasonable.Good plan. You've already got a few project trucks going, and this allows Ethel to continue being a runner and DD.
David
Yeah, tell us.I haven't read up on any thing yet so excuse my lack of knowledge. Does the dodge turbo mount to the same size flange as the 6.5 manifold has? ie T3, T4 blah blah
Yeah just cut it, rotate 180 or whatever and weld back together.It is a t3 non divided housing and should bolt up, I believe a stud may need to be removed but other than the outlet for the compressor side( cold side) pointing at the fender it would require minor mods to run one.
