Oh! ryoken, While i have you here, does orange peel occure in all the layers? Primer/paint/clear? Or does it not in some layers? I ask because im considering asking them to do a cut and buff, or whatever is required to minimize orange peel. If i had it my way, i would have NO orange peel. But if thats going to be an outlandish request/ amount of money. I will just deal with it. I mostly want to know i guess if sanding the color coat would be required, or if a "cut and buff" of the completed truck (just the clear) would eliminate the orange peel.
if the primer is dead flat prior to paint, which it should have been, but isn't always with lazy bodymen, you should have very, very little orange peel thru the base.. the stuff is super piss thin and lays out smoother than laquer.... it can be color sanded, but you still have to put a couple color coats back over the top. so the only time I ever color sand the actual base is if there's an issue.. such as sandscratches, etc..
now, the majority of all orange peel is in the clear... many things affect that, mostly thicker viscosity material.... spray technique, pressure, etc can also affect it, but it's mostly viscosity...
the way to lessen OP is thinner clear with more coats generally... also, on all my higher end, showy paint work I do, ya put a TON of clear on.. it gives you plenty to wetsand to make it a sheet of glass...
my blue Chevelle had 8 coats of clear, wetsanded to glass...
normal, 2, 3 coat clear jobs, sander/buffer beware.. I ALWAYS wanted to be the one colorsanding my paint work at the shop.. it's just safer, you squirted it, you have a feel for how much is on it..
most collision shops will just give it a spot sand for dust spots and maybe some heavier peel, than buff.. just what they need to do to make it look presentable and out the door.. generally they aren't gonna go in and sand it balls flat...
