How will my K5/truck look with xx" tires on xx" of lift?
You'd have to ask my son but if you do the geometry correctly it will prevent the Blazer from flopping forward rollover into stopping or dropping on it's side instead.
It's what happens when you home school. :D
K10 with 35x12.50 on 15x8 wheel and stock suspension. Miner fender trimming.
-For your safety, stay where it's safe
Top two are with 39.5 TSLs on 1 tons, 4" front springs, shackle flip rear with front and rear zero-rates and minor trimming. The bottom three are with the same setup, only 42" Iroks. Sorry for the quality of the bottom to. I left the camera when I went to the shop. All I had was my cell phone.
I can see how that stinger could help. It would have kept a friend of mine from totaling his '91 K5.
81 K5, 6 inch skyjacker, 3 in body lift on TSL 39.5 and 1 ton running gear.
Bottom picture is a 84 K10 with 6 inch lift and 42 tsl's
6" Front springs with zero rate, 1.5" forward. D60. Rear worn out 4" springs, ORD 2.5" flip, Zero rate 1.5" back, super shackles, 14 bolt. 38.5x15 boggers on 10" wheels, 4" BS. Front not trimmed enough, but Boggers like sheetmetal.
Cell phone poser shots, no shocks.
Hits the inners some also but I'm not too worried about it.
383/400/208/60/14/38.5
4' lift with two 35' Super Swamper SSR's and two 35' Big O X/T (Temp till I can afford two more swampers)
Here is mine-about 10" lift with 47" LTB's
I still need to do a lot more trimming...
Just got it, 35" ProComp Xterrains on 6" Superlift springs all the way around, Zero Rates in the rear and 1.5" back. (please no comments, it is going under the knife soon, I will post updates when done :) )
36" tires with 9" lift
i have 36"x 13.50x15 iroks, 6" lift springs all around, shackle flip in the rear(No lift though) and a 3" body lift. the front fenders are cut a little
