In this thread I will attempt to 4 link the back of my suburban for cheap
Right now I am considering buying brackets from shaffers offroad that will weld right on
Cost is 150$ for brackets only, the dimpled plate isn't included.
Or I can use the stock front leaf spring mounts
While quite booty fab it did work well for this for a few years
Also, I will be using tractor joints. Total cost will be under 100 dollars for all of them. And to be honest with you I also want to do it just so I can make a thread on pirate gen4x4 and enjoy the responses.
I will go to a high quality joint when I have extra money.
And as far as link material, I'll go down to the local metal supplier I think they should have enough remnants to do the links.
And the truss would just be something simple like this
And as far as shocks go I am going to try and find some used coilovers in the 300-350 dollar range. Or I could always go to FOA's.
But would I need 2" or 2.5" shocks? The 2.5 cost about 100 bucks more.
Coils and shocks seem like they will be the same as the cost of one coilover so I will try and go all out the first time.
Sincerely,
Howdiyduty
Sincerely,
Howdiyduty
ask rdn2blazer or whatever his SN is... i bet he's got thousands of dollars in a handful of drill bits!
