Got some snow and ice while the ring and pinion was out of the scout so I took the work truck out to play around a little. Had to do some work too
Had a scrapper buy an old junk roadgrader where I work and showed up with a giant torch to cut it up. Used liquid oxygen and propane. Im sure some of you have seen them before but I haven't, thought they were neat.
Cut this road grader into pieces that two guys could pick up and load on the trailer in about 3 hours.
Finally got my ring and pinion back in so I decided to work on the scout a little
Built a bumper out of some scrap stuff I had and a piece of 3/8" plate. Also picked up a smittybilt winch that was on sale for $275. So far (haven't been wheeling yet) Im very impressed with it. Its not a warn but it is much faster than the two ramseys and engo winches that a friend of mine has. I figure with the cost of a wrecker and the likelihood that one wouldn't make it to where I would get stuck, if it pulls me out twice its paid for itself.
Also got the doors put on and with lots of work got the windows rolled up. Gears are all stripped in the cranks so its either up or down. Got the heater working today also so I should be good for a cold weather ride which may happen tomorrow.
. Anyway he had this roll cage sitting in a pile of junk and we measured and it was real close to the dimensions needed for the scout. We asked him about it and he said that since we had to pull the tranny he would throw it in the deal.
. So I started messing with it and ended up cutting it all apart and redoing it while adding in a bunch of bracing and gussets from stuff I had laying around.
. Oh well at least I got some proof that the scout leaves my driveway.
