When I drove my friends '87 C-30 ramp truck with a 6.2 / SM465,it felt like it had a lot more guts than mine,the TH400 in my truck probably wastes a good amount of power..his truck likely had 4.10s or lower gears being a dually though..mine ,I dont know whats in the diffs,no tags,and I have never had the covers off--feels like 3.42's or even higher,if they had gears that high in 14 bolts SF's...it could be lower ,and the tires I put on it that are 265/75/16 make it feel like its too high geared with the automatic and low HP..
When his ramp truck broke the crank after another person borrowed it and most likely whaled the piss out of it,I scoffed the dead motor for parts,it had a new GM oil pan that mine needed badly (and still does!
) ..and it had a J-code intake too...if it hadn't sat in a field for a year before I got it and outside on my engine stand since,I bet if I had a good crank to put in it,it would have still ran great..
I want to swap the intake "someday" but I've been waiting for my crusty injector lines to fail,so I can do it all at the same time..
I cant say I feel as confident working on the diesel as I do on gas engines--I have not had to do a water pump on one,it looks intimidating compared to a six or V8 gas one..ditto for a timing chain or injector pump replacement..I dont like the fact you must pull the injector lines and intake off to change a stupid valve cover gasket either,a 15 minute job on any gas V8...
My driving impressions of the 6.2 are it makes the truck feel more like a tractor or backhoe,its noisy,sounds like a loose rod or two slapping away compared to a gas engine,it gives me anxiety sometimes,and it sometimes idles rough ,makes you think it wants to stall,but never does..once you get it rolling over 40 mph,it seems to quiet down a lot though..the extra insulation and firewall covering does help kill some of the diesel clatter,but to anyone used to a "silent" gas engine,it can be a bit unsettling...and you have to turn it off at the drive thru ,if you want them to hear your order too...and not smog out the inside of the coffee shop!..
I can imagine a military version with no interior or the firewall padding will sound like a tin can ,the diesel makes things in my cab vibrate and buzz at certain RPMS and I'm sure it would be very distracting in a truck without the sound barrier and interior..
My pickup seems to feel like its holding back sometimes,like a brake is dragging or something..maybe its just the lack of HP or the fact its a 6200 lb beast empty,I dont know..I have checked the brakes and one front caliper might be dragging a bit sometimes..the rotors were all rusty from sitting so that might be the cause too..
I dont know what year my pickup's engine is,or how many miles it has,supposedly it was from a mid 80's truck with 78K on it from a salvage yard ,but I have never looked for ID numbers or confirmed what year,and every salvage yard engine ALWAYS has less than 100K,we all know how that goes...
..it does run decent,it misfires a bit at idle,always did,and who knows what has been put in the fuel tank,I have yet to replace the Wix filter in 10 years,it looked new when I got it,so I just drain the old fuel out once in a while,it always looks clear,no water,so I let it ride..wouldn't hurt to change it I suppose..but I doubt it'd run any different..
I recently filled the tank in it for the first time since I got it too!..that cost 55 bucks..
My Burb has 150+K on it,fas as I know the engine is original..it blows a little smoke out of the drivers side bank,but I think it needs a good highway run ,maybe the injectors need a dose of cleaner--the PO ran it on a lot of "bio" fuels supposedly,and it had about half a tank of kerosene added to it just before I bought it too...the engine sounds quieter than my pickups and feels "tighter" ,so it probably had decent care as far as oil changes...wish I could hit the lottery so I could put it back on the road and get the 700R4 fixed and use it some,before it rots into the ground..
