Is the 203 hurt? Maybe too much power shifting it...
Using the 241 range box definitely gives you more options
No, it is just rusty inside but thats how its always been since I got it. I would like the lower crawl gears too
Tell me about it! Its actually being built*Hurry and build so we can go wheeling!
Are you doing all this yourself?Front end is in! Hoops and bumpstops. Hoops poke through the hood just a little. They will be tied together and an engine cage added. Pictures are at full bump. Got a second set of fox bumps for the rear as well. 4 link w/ the full hydro. The kings will be going up front because they are 14" travel and the 12" travel icons will be moving to the rear on the trailing arms.
No, its a motobilt frame kit. Similar but still uses some of the stock frame.are you using a goat built kit?
Thing is green right? Now it has a name...
Haha, is this because its going to be lucky and not get rolled
Hahahadon’t let me spot you![]()
No double shear ?Front end is in! Hoops and bumpstops. Hoops poke through the hood just a little. They will be tied together and an engine cage added. Pictures are at full bump. Got a second set of fox bumps for the rear as well. 4 link w/ the full hydro. The kings will be going up front because they are 14" travel and the 12" travel icons will be moving to the rear on the trailing arms.
Artec arms ?Haha, I might not need a spotter now with this little body.
It is, just hard to see. The connecting rod is painted black
Yep. They have the other set of holes from when it was hydro assist w/ tre'sArtec arms ?
This is a trail gear kit I plan to use I got from Facebook market place should be good lol.@Chevk587 are you going with the psc kit for full hydro?
