You're just saying that because you don't want to admit that my red, big block powered, Q-jet truck will beat your red EFI big block truck.Actually a quad-a-junk is uncool at any age.
Oh, and mine has been to Moab and played on the rocks!
I assume that you are looking for more details than what I posted earlier.So
How about some tuning updates on the EFI?
Each adjustment is real time, it doesn't save it. You have to remember in order to go back. You can save tunes, but since the system learns, it will keep changing if necessary. You could use a notebook to remember where you were for some of it, but you may need to drive it some to let it learn. This would mainly apply to AFR set points. The timing control is instant results, but it could affect the fuel trim, and require a little bit of drive time.do you need to remember what you do ? or is there a go back button ? or each adjustment gets you a saved tune ?
Slow progress...What happened to the bumper?
Nice nameSlow progress...
But someone is bored and bumping threads..
To answer this question, someone knows that I am working on a rear bumper, and is playing like a septic pump... and changing thread titles..What happened to the bumper?
Fat guy in driver seat? Idk hahaSo I measured the top of the door handles
58" passenger and 57.5" driver.
on real 37s
explain that
no, jerk....Fat guy in driver seat? Idk haha
Looks good so far! You going to build a spare tire carrier for it?Cue the fail music from the trombone..
Didn't get as much done as I would have liked.
I got the plates for the rear bumper marked and a couple of holes drilled to match what was existing in the frame. Got more of the plan made, height to clear tailgate and how tight to the rear crossmember, where to cut slots for the 1"x3" flat bar to pass through and a basic idea for the sides. Then talked to my son while he put thermostats in his Dmax. Didn't go back to it since we want to get it back to John's work for some cutting time. He has done all of the work to it so far and is doing great!
He started out with a piece of 3"x6" tubing and did the taper and box for the license plate.
