CrpMag122
I saw that where you were at and immediately the Jeff Dunham Walter skit went through my head. Had to post something about it.Lol I have lived in Arizona my entire 29 years.
whats wrong with em?Better fix those trans cross member bolts while your under there. Looking good!
They're in the wrong place, they are not spacers, they are supposed to be above the frame rail not under it. The crossmember should be flush with the frame.W
The bumpstops bracket is the perfect reference to jig this up on both sides. Since most trucks still have them it makes the build a little easier. We still check to make sure the wheel is centered and there is no clearance issues at bump.This is awesome! I would love to do this setup to my duramax for a SAS some day. Why did you leave the stock bumpstop and bracket? You should come up with a way to do coil springs with this for those of us too cheap for coilovers. Cage Offroad used to offer a SAS kit for the 88-newer chevys just like this but with coilsprings.
Nothing hits anything at droop or bump.That coil over isn't gonna hit the steering shaft at full compression/ full droop? Looks real close.
