dave w
But I did change the fuel yesterday. It didn't make a lick of difference...
The thing is though, the engine started, and ran off of that dead batery all the time. I never touched the timing during the engine swap. I only removed the distibuter cap to get the oil pressure sender plugged in...
It's never easy to figure out a "NO Start". I know I'm new to this board, but I've been working under the hood of cars for decades!
I've learned plenty from my experiences under the hood, and the experiences of other under hood workers.Maybe try pouring about 8 ounces of gas down into the intake manifold, then immediately try starting the engine. If the engine starts, but dies after running for about 10 - 15 seconds, the most likely problem is the engine is not getting fuel. Only pour about 8 ounces of gas down the intake once an hour!!!!!!!!!
If the engine will not start with gas poured into the intake manifold, then the most likely problem is the engine is not getting spark.
Every time I've had a "NO Start" engine it was because of one or more of 5 things.
1. No Fuel
2. No Spark
3. No Air - Because the timing chain broke, so the valves would not open / close. Also no spark because the timing chain broke and the camshaft would not turn, so the distributor rotor would not turn. Also no fuel because the timing chain broke the camshaft would not turn, and the mechanical fuel pump would not pump.
4. Insufficient starter speed. Either the battery was weak / dead or the starter was weak / dead, or the battery cables were corroded on the inside of the insulation, or the battery cable connections were corroded.
5. No Compression - see #3 because the camshaft would not turn, the pistons hit the valves and made holes in the pistons and bent and broke some of the the valves!
It is always one of the 5 things I've listed above, for an engine not starting. I'll buy a you a six pack of something cold, if the problem is something else.
dave w
