well, yeah, it does, cuz the starter amp draw goes up when the voltage is down... it's not as much as if say, everything was running thru the solenoid, but the number still increases, on something that already has a pretty large variable to it, what the starter draws, which was my original point.... just throwing some POS low amp "ford" solenoid at a high comp motor isn't the same as a spin with your finger tired 305... all ya gotta do is look to dizzles to understand the need for varying capacities in solenoids.. heck, I've seen Detroits pulling 6, 700 amps thru a slave...
