Tacked in a dash bar to start visualizing how I'm going to make my dash and burned in the two tubes that pass through the cab to the exterior cage. Not much but it's something for tonight.
Still looking better and better.
Dumb question here - how are you going to seal up/ weahter proof the cab where the cage comes inside? Expanding foam?![]()
Avery you are leaving the cab corners unsupported. You need another tube out as far as you can on the corners to connect the inside of the cab to your outside B pillar.
I fear those corners will crush in a hard roll. That would be bad
No I'm not leaving them. I'm far from done...
Thanks for the kind words. Just get out there and do it! I don't always know what I'm doing, I just kinda go outside and start bending and notching until I like how it looks.I'm always impressed with your skills Avery, and the fact that you do this out of your driveway. You give me a little bit of hope that I can do not even half of what you're doing in the same manner
You're giving this guy way too much credit. His sister does most the work.![]()
You do good work young man. I truely appreciate anyone who takes pride in there work, kudos![]()
