A good package showed up at the shop today. Should be fun to try and stuff these in here, they're pretty big.
seats look badass. you had a bench before, didn't you?
Should be a huge improvement.
Keep it up!
I agree that they will be more comfortable and give more headroom if you tilt them back a few degrees. What kind of harness are you running?Your gonna cross brace the interior cage b pillars right?
After you weld in the seat belt bar?
Seats look sweet. You can always go major floor surgery if you need to lower em a touch.
Also you will be amazed how much room there is without a dash. I actually started sliding my seat forward of where I usually had it when I eliminated the dash
You even got the piping on the seats to match your blue color. Sick!I agree that they will be more comfortable and give more headroom if you tilt them back a few degrees. What kind of harness are you running?
with the cross on the exterior hoop just inches behind the cab I wasn't planning on crossing the interior. Just a seat belt bar.
I thought about floor surgery but obviously I'd like to avoid it if possible.
Cage is coming out great
Are those regular height seats? how tall are you?
vulcan caulk works pretty good to seal holes
I would join that inside b pillar to the outside b pillar in more than those 2 places then.
I think you would be fine in a mild roll but in a harder roll I don't think those 2 little tubes will be able to take the force
Very nice. Little pockets on them too??
if that bar says pass, does the other one say fail?
thats why you have to swing off the top bars like its a jungle gym. just keep your feet dangling.Hey those come out pretty good. When you trip on those bars and fall out your truck Ill just give you the "I told you so look" while laughing hysterically![]()
if that bar says pass, does the other one say fail?![]()
What about just some decent size tube gussets in the corner going from those B pillar legs to the tube running across the top back of the cab?
I do the same thing to my sided parts.
