While I'm waiting on the axles I'm shifting back onto the doubler. I pulled the exhaust, crossmember and old 208 case out this afternoon. Spilled just about everything I could spill in the process too.
Put the adapter off my 208 onto the doubler for a test fit. Can I just use RTV here instead of the gasket that was on it? The other side uses an 0-ring but where the adapter mates to the case I wasn't sure if RTV would hold up.
In that bag is a new Poly mount to go with all the other poly mounts I've been swapping to.
