CK5 Network
Become a member of the largest online community for Chevy K5 Blazer, Suburban and C/K series truck owners!
L18 8.1L swap resource thread
Blue85
Yooper
Premium Member
Keweenaw
I thought the same thing when I saw my 8.1L starter shared the same case as a 3800 starter. The larger diameter flex plate/flywheel does give the starter more leverage, though and the little starter had no problem cranking it. I had some questions about this but never posted up here. The 2003+ starter is a different style and it seems the block itself must have changed to accommodate.
Unlike LS engines, the nice thing about the 8.1L is it has the staggard bolt pattern and same ole 168 tooth ring gear GM has used for decades. Any starter from decades of BBC’s or SBC’s with the staggard bolt pattern and 168 tooth flywheel will work. Don’t feel obligated to spend crazy money to use an “8.1L” application starter
From page 1 of this thread:
- The L18 8.1L has the same foot print as older BBC engines and will bolt in the same as any other older SBC and BBC. In fact, the L18 will accept any exhaust manifold or header from older BBC engines. The starter motor from any older SBC and BBC for use with a 168 tooth flywheel will also fit the L18. Any transmission from an old PowerGlide, TH350, TH400 to Allison, to NV4500, etc. will bolt on to it as well.
I like to run Denso 281-8002 starters on everything. The Denso starter on my Suburban’s 8.1 is the same exact starter that was on the TBI 5.7L before the swap. These starters aren't cheap but they will be the last one you ever buy. This is the starter UPS uses where it lives up to their punishment of starting hundreds of times a day. It will turn ring gear teeth into razer blades long before the starter wears out as the Rockwell hardness of the starter drive gear is harder (55) then the ring gear on the flywheel/flexplate which was around 35. Us guys would probably never see the ring gear teeth get worn down like they do.
I think the shrouded nose of the Delco style vs the open gear of the Denso style was throwing me off. I have a aluminum inspection cover and not the stamped steel one that came with 8.1L trucks, but I suppose as long as the nose diameter is the same, they will interchange. It's just weird that the Denso style isn't listed as compatible for anything before 2003 and not studying the pictures I just accepted that.
EDIT: I've had the Denso starter on for a while now and it's great. Sounds good, cranks fast, don't even worry about leaving the radio or lights on for a bit now.
jtrux
Premium Member
San Antonio, TX
went and looked at a 2001 3500HD std cab today . she has 80,xxx miles on the od and the nice 8.1 / nv4500 combo . told him i would take it for his asking price of 2500 bucks . going to keep it as a work truck for my self . Pics to come soon .
I'm sure it's been covered but maybe not. Are the GMT400 accessory brackets the same as the GMT800 accessory brackets? Curious because I am looking at an 8.1 for my '93 K2500.
sweetk30
I build stuff
Premium Member
horseheads , ny 14845
i know in the begining of this thread its all layed out . 1/3 the way down page 1 with pics and info .
i will have my here by this weekend i hope . he is waiting on the bank to send the lean release form . he is ready for my payment method and i am ready for the truck .
RootBreaker
3/4 ton status
Premium Member
Williamstown, NJ USA
You need to put a fuel pressure gauge on it and post up what you have when it's running. Normally an 8.1 needs 55-62 psi running. A fuel pressure regulator on a 2001 engine is adjustable. It's a small Allen head screw and little movements make a noticeable change. Watch your fuel pressure gauge as you make the adjustment. IIRC Larry tweaked his above spec slightly by a couple of pounds.
my 02 looks like a safety torqs and I am currently at 45psi and i am guessing it is this guy? 20210724_093113.jpg
RootBreaker
3/4 ton status
Premium Member
That's it.
man is it beat.. i got it to go ...but started stripping... actually went too high but got it to 58psi... did not go for a run cuz it is hot out and i am frustrated... i replaced rear main but i have oil on filter and dripping...most ikely rear main!!!!
