I think I have it figured out. The relay is pointless wired this way it is hot, and activated all the time, if my suspicions about the red wire spliced with yellow fused wire are correct.
This condition will cause a draw on the battery. The only thing actually switching is the temp sensor.
So lets say we fixed the yellow fused feed wire to keyed hot. The system would function, not as efficiently as it could. By putting the temp sensing switch between power and the fans we are adding resistance to an already heavy load. As evidenced by melty relay socket.
My solution puts the temp sensing switch on the relay control side, and has only the relay between the fans and the fused battery source.
Up to you how you wish proceed.
