clstolten
- Joined
- Sep 4, 2002
- Posts
- 356
- Reaction score
- 0
Building a gantry crane
I know at some point the body will have to go back on, and mostly that will happen a few times in this build. I also know that I will need to cycle the linked suspension during the build to get it set up optimal. Plus, it seems like I am always lifting heavy stuff into my truck or onto my trailer. The best way I could figure on doing all these things given that I am doing this in my driveway, was to buy or build some kind of a gantry crane. I thought about buying a four post lift and setting it up in the driveway, but I rent this house. Craigslist had some good deals on those.
Here is what I wanted from the gantry style crane
-Be able to lift a couple ton
-Roll around with a load
-Be able to roll under a 7' garage door
-Be able to clear at least 10' under the beam
-Be able pull my car hauler in between the legs of the crane.
One option I found was to buy the chinese harbor freight gantry. It only lifts a ton, it isnt wide enough to pull a decent trailer under, and I wouldnt want to roll it around with a load hanging from it. Also it will not roll under a standard 7' garage door. There are other gantry style cranes out there, but they get expensive quick.
I ended up designing a crane using some software I use at work. There are two full sticks of 4x4x3/16 wall square tube, one full stick of 3.5x3.5x14 wall square tube, and a 10'3" I beam that has an 8" web. I bought the tube new, and found the beam in the scrap yard. It is all usa steel. Got lucky and didnt even have to cut the beam, it was the perfect length. In total about 800 lbs of steel.
Here is how it all went together
These are the upright pieces that will get welded to the i-beam. Crane beam height is adjustable in 6" increments. It was a bieber getting the .75" hole drilled on my bridgeport. Bridgeport is in the corner of this small garage and length and weigt of these made it not so fun. .75" holes go thru both sides. The two smaller .5" holes that you can see are for the winch hook points. I use boat trailer winches to telescope the beam and then pin it with a hitch pin while lifting.
