So, my 1985 K5 is an open carrier truck. There is no G80 designation in the glovebox and now that I have the rear end on jack stands, I need to make a decision.
I don't understand why GM would not put a limited slip in a truck like this, much less a 4WD vehicle??
If I just keep the open carrier, what capability will the truck have? If I go to the beach, will I be doing one wheel rooster tails?
I called a driveline shop, and their pricing was outrageous. They want $750 labor only to tear down and rebuild a rear end, not including a new carrier, bearings, etc.
I have changed axles and bearings etc.. Even built engines and degreed cams, etc...... However, I have never set the backlash for a new carrier assembly.
What should I do? I have considered lunch box lockers, but I have grown concerned; I don't want to take off around a corner and have another wheel engage and end up in an accident etc.
What would you do? Leave it Open or something else? I have access to G80 axles, but their condition and function is unknown.
UPDATE- based on everyone’s recommendation I went ahead and ordered a TrueTrac
