andyblack
Registered Loser
Looks fine to me. Sounds like you need to try to take some time off and go out and wheel this thing a little. After you fix the clutch, that is.
That'd be cool. I haven't actually ever met anyone on this forum so i'd be cool to have a face to put with the screen name.![]()
Was your guy having work done at Tony's? They do pretty good work at that shop. The guys at mid-atlantic 4x4 are good guys but mostly deal in Mall crawlers and lifted daily driver ifs rigs but are always more than happy to talk about wheeling and lend a hand when they can.
How's the future Coal Roalin' K5 coming?
Truck looks awesome![]()
A lot of the items on the list I have already bought everything for, just haven’t had time to install.
If you weren't on the exact opposite side of the country I would be there for sure.
I can't make it this time.
Thanks for the props guys
I've been feeling burnt out on the truck lately and I think it's because of all the loose ends and half done stuff, so i've decided to build a check list and try and wrap up as many loose ends by July 15th and then wheel the piss out of it.A lot of the items on the list I have already bought everything for, just haven’t had time to install.
Here's the Completion List:
Dana 60
Rebuild upper and lower Kingpins
Repack Bearings
Install Mad4wd Outer axle seals
Install spicer 35 spline stubs
Install Mile Marker 35 spline locking hubs
Install Lockright
Install ORD Draglink
Replace Pinion Seal
To Buy
SPL554x U joints
Pinion Seal
Suspension
Install engine cage w/ shock mounts
Build Rear Shock brackets
Check Everything/ replace all standard nuts with lock nuts
Engine/ Trans/ T Case
Install and tune Propane Kit
Bleed and Adjust Clutch
Grease T Case Shifters
Check and Fill All Fluids
Oil Change
To Buy
Misc Fittings
Tank Brackets
Interior
Install Mojave heater
Complete Diy4x Dash Install
Install New Wiring harness
Install Gauges
Install S&W Cage
It's a big list but I'm hoping I can get to most of this, so I can get this thing wheeling and finish this phase of the build before the baby comes at the end of July. Would anybody if the Maryland/DC/Virginia Area be interested in doing what Dave did in Michigan but more like a build day. I think a solid Saturday of more people than just me banging away on this would go a long way. I'll buy lots of beer and pizza if anyone is interested![]()
Hey Stump, I really like what you got going on here man, be wary of that S&W cage...what part # did you get? Check your pieces to be sure they are what they say they are, and realize that if you got the back family extension, it won't cover your head back there????
Good luck with the build day, we had a blast at mine. If anyone can attend I highly encourage helping out![]()
Spending time with the family is always a good investment.
