The recirculation air is the "max" setting. I personally wouldn't buy a kit, I tried Vintage air in my '70 and didn't like it for multiple reasons. The square trucks have a good system, just fix anything and get a compressor mounted. My '90 can put out 20* air when the humidity is low and the cycling switch is stuck on.
The problem that you will have is the compressor. Lots of the aftermarket brackets use the R4 compressors like the original. Those aren't well know for being a long lasting unit. And some are noisy when new. But it should hook up to the factory lines no problem. I have seen a truck with Holley brackets on a 6.0 using all of the original style lines to the compressor.
I would use a new parallel flow condenser, even though they don't fit as nice as the factory one.
